Thank you for more examples. Clarifies a bit more for me. But, also muddles a bit as well.
In the round peg in the slightly loose hole example, is it the material with the loose hole that is being rotated, and causes the peg to rotate within the hole. And could that peg actually be rotating in the opposite direction?
Shoot, were it not for the lousy weather out and the Super Bowl, I might just go out to the shop and create an example in wood. r perhaps even in metal!!!
Bicycle pedals:
Indeed, that beings back kid memories. My earliest use of tools involved taking bicycles apart. Mix and match done more than once. The latest was a full restoration of a derelict. new fenders, pedals, tires and tubes, matching wheels and new pedals!!!
Jeweled no less. Oh, grips and a basket of the bars.
No gears then, one speed. New Departure Coaster brake. Two little flaws, a break in ewither and voila, no brakes!!!
To the point. As the pedal spun on bearings around the shaft that had handed threads into the crank, it seems that no motion would be imparted that might allow the shaft to back out.
But, misuse often resulted in pedal disintegration
nd kid feet right on the shaft. Then, yes, unless very firmly seated, backing out seems inevitable.
Agree lug nuts in different rotational axis would act differently. Little, as Bob says, or not at all. Not to completely disagree with Bob, but, I tend to the latter.
But, for the exercise of grey matter alone, very meaningful discussion. Beats the h… outta that other …
Carl
