Ok so one thing I don’t necessarily like about my 97 xk8 is that if I stop somewhere after driving and go to open my door, both my driver’s and passenger door unlock. Is there a way to make it where I just unlock my driver’s door when I get out? Maybe being a little paranoid, but oh well
I will be the first to admit I don’t know the answer to your question; but I have a suggestion. When you stop after driving and shut down; try removing the key from the ignition and pressing the unlock button on the fob one time. That should only unlock the driver’s door. It should work the same way as if you approached the locked car and pushed the unlock button once, opened the driver’s door and got in. I don’t know if it will work, but can be tried easily. Let me know if it works.
I’ll have to try that and see. I didn’t even think about doing it that way
