Hi all
I have a 1988 XJS V12.
What I really want to know is what should be the operating temperature of the car! I have installed 4 very powerful electric fans front and rear of the radiator and have the 82C thermostats. The radiator is a new aluminium high performance radiator and I have modified to to be single direction. The water pump is also supposed to be the high performance type and is new. The temperature gauge sticks around the bottom of the N under normal gentle driving, however it climbs to the middle of the N and slightly higher when I start to push it. I also installed an independent temp gauge connected to the other bank. When the temp needle is at the bottom of the N the analogue temp gauge shows around 88C. When the needle is in the middle of the N, the analogue gauge shows around 93. When the needle approaches the top of the N the analogue needle is showing 96C.
When I slow down the temperature slowly fall back to 88C-90C.
Is this normal behavior? Most of the posts I have read seem to work the other way around, temperature rising at idle but cooling down after the car starts to move!
I should also admit I have the AJ6 engineeringâs ECU, larger throttle bodies and exhaust system installed. Ambient temperature is around 33C.
A friend has an unmodified XJ12 1990 which has a temperature gauge that shows actual temperature. The green part of the temperature gauge runs from 90C to 130C!!! His car was showing 105C under normal driving!!! Iâve attached a picture of the instrument cluster.
