Original internal and external engine parts
General question-I did a complete rebuild a few years back and went to triple SU’s as well. I realize this may be a bit of a subjective question but are items like the original factory pistons and strangleburg carbs and manifold worth any type of value to me for resale or others in doing a rebuild? The car had great compression and ran great (aside from the rod-knock). If someone else could use these parts, then that’s a consideration… Thoughts?
Car is a 70 OTS…
Pistons; not really. By the time you’ve got to the point where you can replace the pistons you’ve spent so much time and effort that $500 for new ones is good value.
You might get a few hundred for the Strombergs on Ebay etc.
