N-5 was replaced by N-11Y (Y = protruding cone) due to reports of fouling. 5 is a hotter plug than the 11. You can also used the N-12Y which is a marginally cooler plug still. The Y suffix plugs have an electrode that protrudes further into the combustion chamber.
I used to use NGK BP5ES instead. (Just donāt tell the purists). These days I go for a longer lasting plug suited to modern fuels BPR5EIX. These last for tens of thousands of miles, which equals less wear on the plug threads, an important consideration for a still well used 200,000+ mile engine.
I gave up on Champions, 30+ years ago, due to a large number of bad plugs: switched to NGK and have never looked back. Used them in the Jag, use them in my Hyundaisāwhere they last 100,000 milesĀ±-and in the Rover.
The Champion number system changedā¦so the N5 (the N5C was an improvement with āCopperā). actually became the N9, and a step hotter was the N11.which the Factory selected, not because it was equal to the N5ā¦but because it was hotter to prevent cold start problems and fouling problems that had been reported. .(again the N11YCā¦with extended tip and copper would be the better improved plug). You see in the Service Bulletins this was for protection of āoiliing upā, (fouling) in slow city traffic and in the earlier bulletin cold start issues. The Champion range is hotter as the number goes higher, so the N12YC, often used back in the day, is a step still HOTTER, not colder.:.Colder would be the N9YC only for faster rev hiway touring use, but subject to fouling in town. (thus the Factory āchoiceā of the 11 in the SB) Champion has closer heat ranges per plug. NGK covers a wider range in one plug. Most will use either the NGK BP5ES (a bit hotterā¦if mixed driving, or running rich or burning oil) or the BP6ES a bit colder if hi way, higher rev, clean engine burn. So while Champion has about 5 plugs to cover the range, NGK has 2. (3 if you add very cold NGKBP7ESā¦only for sustained hi speed) . The iridium plugs are really not suited nor recommended for the older enginesā¦they are designed for todays computer fuel injection, electronically controlled engines. ā¦Sparky Nick
I was taught to use a āhotā plug in a cold (low power) engine and a ācoldā plug in a hot (high power) engine, confusing as it seems! These names refer to the plugās ability to transfer heat from its firing end into the cylinder head. A cold running plug transfers heat rapidly from its firing end and is used to avoid overheating where cylinder head temperatures are relatively high. All makes sense until you find manufacturers have codes going in opposite directions! Champion confuses the situation further by having two scales with 53 being cooler than 7:
Unfortunately I didnāt take notes, nor do I recall what I checked when my head was off. I do recall that some different, supposedly correct plugs showed some thread into the combustion chamber - not ideal due to possible hot spots. Also, it is possible to extend an electrode without always increasing the heat range - this is a brand specific manufacture decision. A longer reach effectively advances timing and the current desire to put the plug nearer the center of the chamber. The Jag plug angle and location seems quite poor, which is why I clocked the plugs, even though most engine builders say itās a waste of time. I did make a āmapā of the electrode direction for the future. I know some old engine guys ditched super short electrodes and found some benefit due to even these tiny differenced in flame front travel. Thatās the kind of stuff Smokey Yunick and the like would do (the Chevy ā44āsā had a real short reach). I do think the threads showing is a bad idea, even if my other āideasā are bunk.
How does one āclockā plugs? I assume you have a bunch of different thickness washers, or is it trial and error to find the right plug for each cylinder?
clocking has its advocatesā¦Coil polarity as wellā¦spark should flow from center electrode to the the outer. Some say quite a bit of improvement in this being so, but not noticeable problems if not. Another issue is resistance in the primary wiring, and or in coil to distributor. Resistance in modern extremely high electrical energy modern cars is vey high to protect the sensitive electronics from RF, but his resistance is too high for the XK engine. Plug wires should be quite low resistance, and if no radio, zero resistance or close. Sometimes an error can be made in doubling of the resistance supressors installed. As to the chart aboveā¦the Champion 11 or 12 are on the hotter sideā¦and compare to the NGK5, while Champion 9-10 are colder and compare to the NGK6 range. Simply thinkā¦if the engine cylinder (not coolant temp) will be running fast and hotā¦it is like being in a hot roomā¦you want a cold air conditioner to get rid of the heatā¦ie a cold plug to transfer heat away. Err on the cold sideā¦worst case is it fouls, gets sotty or oil fouled, easy fix. Too hot means too hotā¦a piston top or valve can burnā¦actually quite easily, quite quicklyā¦faster than you may think. A drag car can burn thru in seconds.
Nick
An old Ford āShop Tipsā, back in the points / condenser era, noted that advancing timing cooled the mixture (before any detonation), but heated the plug up, so they advised cooler plugs hand in hand with advanced timing.
An interesting note about Smokey Yunick. One of his engines shown in an old Hot Rod magazine had little holes in the headers. At the time thermocouples for exhaust temp in individual cylinders were relatively unknown to hot rodders. The picture needed to speculate what āSmokeyā was doing drilling holes in his headers.
Did anybody replace them with what and why? I would have thought, when they are listed in the owners manual and spare catalogue they would be correct for the engine.
I know that many do recommend NGK BP5ES but those were not original and would be only an alternative
The various posts in this thread document the factoryās claims to switch to N11 to avoid fouling in stop and go driving. But I never got the memo until now!
Back in the day, we did an āItalian tune-upā once a week, which was to hit 100 mph for a few minutes on your favorite unpoliced highway to clean off the plugs. Anybody else remember that? No Iām not making it up.
My ownerās manual hasnāt changed since it was printed in 1967, amazingly enough, and still says N5 today. So, when I go to my favorite auto parts supplier, I look at the latest cross-reference chart to see whatās the current replacement model, which was N5C last I checked. (I have a full set of tune-up parts in the bin, including these plugs.) Thatās what Iāve been running since forever, and N5 before that. I donāt have a cold start problem, so, after 50 years, Iām okay with the current variation of N5.
When the spark plug threads reach into the combustion chamber, deposits can often form on them, and those deposits can ruin the cylinder head threads when removing the spark plug.
Tom
Hot and very cold plugs. One is a BP5E S and the other a Champion C59CX. The latter is a plug I used when I raced and is really cold as you can see how short the center electrode is. The ground electrode comes this way - you could not gap it. In high CR engines the ground electrode can glow red hot so the less the better. There are plugs available that have no ground electrode - you just need enough volts. I ran leaded gas 112 octane, and the plug would last between 9 and 10 hours before it started to misfire. It comes with an index mark.
N5 or N5C are fineā¦and many N5C can be found on ebay. One would like to think that in 40 years the technology of the plug manufacture would have improved, even is kinda the sameā¦butā¦given products we see daily todayā¦the reverse is likely. Italian tune ups were common among my group of car friends back in the day. I had straight thru pipes with a resonator on my XK120 thenā¦and after being in town for cruising at night, Iād head out of town and run it up thru the gears nearly to red lineā¦and see the glowing orange embers swirl behind me. I will still do thatā¦but my redline now is 3800, not 5800. When shutting down, I do try to run the engine at 2,000 or so in neutral for a few seconds, drop to idle and quickly shut off. Some make the mistake of checking their spark plugs for ācolorā when their last few miles were at slow city stop and go before shut down. (in the XK120 world we have those who want original as from factory sparkplugsā¦now that is funā¦not only rare but have to be black base and Made in England).
Nick
