As I have, unfortunately discovered. My two DDs are BMWs - a 2001 325i (bought new) and a 2007 335i (bought two years ago for a measly $13K!). About ten days ago, the transmission in the 325i (a very nice 5-speed automatic) suddenly and catastrophically failed, after a mere 16-1/2 years and 220K miles! No forward motion whatsoever, and only crawls in reverse.
Now, I’ve done ALL work on these cars for years. And the think I really like about BMWs is that they are about the easiest cars to work on I’ve ever seen. Until yesterday, I’d not seen ANY job on those cars that was particularly difficult, and most have been remarkably easy.
So, when the tranny dies, I thought “No big deal - Find a used slush box, and swap it out!”. Well, not so fast as it turns out. The 325i came with two different trannys - the ZF, and a GM. GMs are a dime a dozen. The ZF, which my car has, is actually pretty hard to come by, and a LOT more expensive. And, no, they are NOT interchangeable. But, I got kinda lucky, in that the only low-mileage one I could find anywhere was right here in Santa Cruz! And it was “only” $1200, as opposed to ~$400 for a GM.
Anyway, I took the tranny out yesterday. While I won’t claim it was fun, it wasn’t really THAT bad except for two things: First, half of the bolts that fasten it to the engine are all but inaccessible. I had to use, literally, 4-5 FEET of extensions on a ratchet wrench, and a LOT of patience to even FIND the heads of the 5 TORX bolts around the top. But the REAL pi$$er was that unlike ANY other engine I’ve ever worked on, the starter actually bolts to the bellhousing, not the engine! With the bolts removed, the starter was still SECURELY locked to the bellhousing, preventing the transmission from coming off the engine! The two were held together by a single ~1/4" dowel pin, which was apparently rusted in place. I had to use a looooooong piece of steel pressed up against the very small, exposed back face of the starter, and whack on the other end of the steel to break them apart, so the tranny would come out.
The starter is up under the intake manifold, completely covered by hoses, wiring harnesses and a ton of other stuff. I quite literally could only SEE a very small part of it, and could barely touch it with the tips of my fingers. I don’t have a single clue how you could possibly replace the starter, without removing the intake manifold from the engine. I don’t even know how I’m going to get it re-attached once the new tranny is in place. But I can say, for sure, changing THAT starter out would make doing a E-type starter look like childs play.
Ray L.
