I have one of my BMWs in a million pieces, due to a mysterious failure about 10 days ago. The victim is a 2001 325i with 225K miles on it. It was running fine, then all of a sudden it wasn’t. Computer complained about misfire on cylinder 2. I’ll spare you the details of the diagnosis, but bottom line is: A piece of one of the cylinder 2 exhaust valves went missing:
I am completely baffled about what happened here. There is not so much as a tiny scratch anywhere on the piston, chamber, the remaining part of the valve, or the valve seat. The valve is NOT bent at all.
The piece, as you can see, is not small, and the metal is quite thick where it broke. And it DID break - it is NOT burned. As I said, the failure was instantaneous, and occurred under conditions of low speed and very light load. The only explanation I can come up with is a latent defect in the metal itself, that simply waited 225K miles to fail! Any other ideas?
Other than that small problem, the engine appears incredibly healthy. At 225K miles, the compressions, other than that one cylinder, all fell between 175-178 PSI, which is, to me, remarkably high, and almost unbelievably consistent. There is some VERY minor scoring near the very top-most travel of a few cylinders, and at some point in its life cylinder 1 obviously swallowed something that left two very small divots in the piston and chamber, but otherwise the pistons, bores, valves and seats all look great, and the bores still show clear cross-hatching! The head itself is incredibly clean - ZERO sludge found anywhere, and ZERO corrosion in the water jacket. It all came apart very easily (if you ignore the ~6 hours it took to remove the 16 nuts holding the exhaust manifolds and primary cats in place).
Once all the parts and special tools arrive, it will get put back together with 24 brand new valves, and the tappets will be rebuilt, as will the VANOS. The cams, cam bearings and tappets all already look like new, but I figure there MUST be at least some crud in a few of the tappets, and they are very easy to disassemble and clean. When it’s done, it should be ready for another 225K miles!
But I’d really like to know WHY this happened!
Ray L.
