I am currently assembling my e-type S1 '63 and am trying to sort out the P-clips for the car.
Jaguar used a number of P-clips made by Lucas. I am not sure how complete the list is:
but it should show most P-clips used in '50ies and '60ies by Jaguar.
I have most of the dimensions, however I am still missing a few (yellow highlited).
The clips that are listed in the SPC are as follows:
I have sorted them to the clip location (for electrical harness clips) and other category.
The numbers on the left hand side are listed purely for the photo naming. The green ones are where I have identified the location of the P-clip.
As you can see there are still quite a few I could not locate.
If you can help, please post photos of other clips that I have not posted already.
Bonnet:
Clip, securing Front Lamp Harness to Bonnet Sides (187079) β 5pcs, I can only locate 4
Clip, securing Front Lamp Harness to R.H. side of Bonnet (187052) - 1pc
Clip, securing Side Lamp Harness to Bonnet (900402) β 5 pcs, I can only locate 4
Clip, securing Headlamp Harness to Bonnet sides (850358) β 2 pcs
Forward Harness
Clip, securing Forward Harness to Front Frame (187081) β 1 pc
Clip, securing Forward Harness (187085) β 1 pc
Clip, securing Forward Harness at Heater Bracket (187044) β 1 pc
Clip, securing Forward Harness to Pedal Housing (187005) - 1 pc
Clip, securing Forward Harness to Bonnet β 1pc
Bulkhead
Clip, securing Screen Washer Harness to Bulkhead (900402) β 1 pc
Clip, securing Panel Harness to lnstrument Panel (187005) β 2 pcs
Clip, securing Rear Lamp Harness (187081) β 2pcs
Clip, securing R.H. Body Harness to Pedal Housing (187052)
Clip, securing Reversing Lamp Harness (187047)
Boot
Clip, securing Rear Lamp Harness at L.H. side of Boot (187048) β 1 pc
Clip, securing Rear Lamp Harness in Boot (187052) β 3 pcs
Other clips (non harness clip)
Clip, securing Vacuum Hose (187085) - 3pcs
Clip, securing Reversing Speedo Cable (187047) β 1pc
Clip, securing Radiator Duct Shield to Front Sub-Frame (187034) β 3 pcs
Clip, securing Vacuum Flexible Hose β 1 pc
Clip, securing Clutch Pipes β 1 pc
Clip, securing Speedo Cable β 1 pc
Clip, securing Hydraulic Pipes to Toe Board (851536) β 1 pc
Clip, securing Petrol Pipe to Frame (187052) β 1 pc
Clip, securing Petrol Pipe to Reservac Tank (187042) β 1 pc
Tadek
PS. Many thanks Jonathan for an update.
