My 1974 XJ12 (Daim VDP 2X6) carbie engine is being rebuilt, including the head.
My mechanic has asked if there are any performance enhancements that can be made to the camshafts or camshaft timing (emissions is no longer an issue)
Jaguar configured cams and valve timing for āstreet useā, Paul - making compromisesā¦
But tuning these parameters is a highly specialized area - maximizing one aspect will influence others. Altering cam profiles will require expertise, which may or may not be readily available - but minor adjustments to cam timing may be attempted on a trial and error, using driving and/or dyno testing. However, care must be taken to avoid valve damageā¦
Likewise, some experimentation with ignition timing is possible - but the performance changes might not be suitable for ordinary use. And may be counterproductiveā¦
Frank
xj6 85 Sov Europe (UK/NZ)
There are some āperformanceā camshaft offerings out there intended (I think) for the E-type V12. My guess is that they offer more power at a higher RPM rangeā¦which probably isnāt well suited to the much heavier XJ sedans.
https://www.terrysjag.com/category/PERFORMANCE-CAMSHAFTS.html
http://www.v12sales.com/Jag-Engine.html
DD
The problem with performance camshafts for the v12 is that only the wrong ones are commonly available. The v12 has so much low down torque (and many cars are geared with a 2.88 differential) that the average road user will spend the majority of time below 3500rpm. If the performance were to be optimised or enhanced for this lower rev range, then it would indeed be an upgrade, but most āsportsā enhancements are for the higher rpm range. Sadly, road users donāt ever really need to go there, so attempting to boost performance above 3500rpm will yield little positive benefit for the average user.
kind regards
Marek
The addās language is a bit misleading, or I am not reading what it says.
Road, road racing or street?
As Marek mentions, torque is a king. Match the "sweet spotā to the need, and the car is alive.
One might look in to increasing the lift, if the valves clear, and leaving the duration as is.
Carl
For a street only car, the best way to increase performance during a complete engine overhaul is by enlarging displacement and going with a higher compression ratio. If you are considering camshaft changes as well, a larger displacement will help to swallow up the normally lower rpm torque loss of a camshaft with a performance profile in a smaller engine. An otherwise equally built 6 liter should make at least 10% or better power vs. a 5.3 liter. And so on depending how far up the displacement increase ladder that you go.
I have no experience building a performance Jaguar V12, but much experience building common Detroit V8ās. I once had a '67 El Camino that I built a torquey low revving 406 V8. At the drags with a nothing special setup of 3.08 gears and leaving the transmission in drive for full throttle upshifts at a leisurely 4,200 rpm, it ran a consistent 13.10 e.t. at 106 mph. The camshaft I used would have been somewhat lumpy in a 350 V8, but the extra 56 cubes of the 406 swallowed it up and helped deliver gobs of torque.
Pretty good advice: there is also the complicating factor of manual vs. auto ābox, that makes what kind of performance mods to do, even more touchy.
Thanks for the advice folks
Ed Iskenderian, who, like the Farmerās Insurance guy, knew a thing or two about camshafts, was asked about which cam was the best for all-round street performance: his answer?
āThe one it came with, from the factory.ā
Iāve devoted some time to the modification of the Jag V12 and from my experience, there are some cams available out there but as has been said earlier, you have to consider the whole package. And then it gets really expensive for the performance increase. The best performance upgrade is a manual transmission conversion. Check Harryās Garage XJ12C video.
Or of course you could always install a GM T700 R4.
I went from 2.88 final drive to 3.31 and am very pleased with the performance increase. Might not be the best choice for those who spend a lot of time on the open road at highway speeds, though. Itās a little busy. But the response for passing is wonderful
DD
Flow chart for these kind of modsā¦
Is it your carā¦yes?
Have you researched, and spoken to others who have done the same modā¦yes?
GO for it!
Doug,
my car has the 3.31 as well and it maxes out at 4700 RPM and around 110 mph. With a 12 cylinder car and the same ratio you have around 1300 RPM and +100 hp left to take you to 140 mph. That should do for most places ā¦ Yet, I admit that 3000 RPM at highway speeds feels a bit more than necessary and Iād prefer the 3.07 axle that was installed in continental cars at the time.
Still, I guess the SI 2.8 MOD would end up pretty much at the same final drive ratio as the 3.31 (4.09 x 0.8 = 3.27).
Best
Jochen
75 XJ6L 4.2 auto (UK spec)
my approach ,5.3,is 700R4 , rear gear 3.73 -1 LSD, in overdrive final ratio is 2.60.
but 1st gear is great for accelleration with a 12-1 ratio, other words engine turns 12 times for 1 rev of the wheels .
700 trans has instantainios shift to second gear! .
ron
i had CRANE CAMS custom grind some cams that gave some more lift , without to much increase in duration, slight overlap!
i have no problem revin 6500rpm , altho 7000rpm can be done , BUT its past the HP peak!
my torque peak is around 4200rpm, its close to the best of both worlds!
if i were to do another engine , i would deffenatly go for more cu.in. Displacement , torque IS KING for a street car!
plus some odd&end engine mods!
now i must say the 5.3 Jag does not have much torque,stock, CONTRARY to what most people think!!
and very true its the whole package of mods that count , and overall weight is the ENEMY.
ron
Im just rebuilding a '85 xj12 for my taste, engine rebuild with the 6.0 version + cams (stock reprofiled) and optimized head and intake. Scraping the lucas system and replacing it with a syvecs that has traction control, cruse control, all the extras as a modern management can do and way more, plus it will control my ZF 8HP70 automatic from a 2014 xj.
For sure with all the suspension upgrades, 17 spoke wheels so it gets up to date with ride comfort.
For sure absolutely nothing obvious for the untrained eye.
If I have time to build a custom exhaust manifold, technicality four, than iāll be visiting every tunnel in my country.
This is my interpretation of a classic car retromod.
Sounds interesting Zoltan. I think you will find that 17ā wheels will bring it up to date with ride comfort by making it LESS comfortable. The handling should be sharper and grip better, but to get that with the same basic steel suspension and taper bearing components you will have more noise and a less compliant ride.
Not everyone values comfort highly, however, so it is your choice. I was unhappy to find I could not fit 16ā wheels instead of the 17ā wheels that my 1999 supercharged V8 Daimler came with. I wanted more comfort but the front brakes on the supercharged V8 cars were too big for 16ā rims.
However, when I fitted 18ā XJR8 wheels to improve grip on my 1995 XJ6, it spoiled the handling by making the front twitchy because the old style suspension did not work well with big wheels, so I compromised on 17ā.
Your XJ has similar suspension to the 1995 XJ so 17ā may be fine.
Comfort is a thing that its hard to judge objectively. Comfort can be that in handles at speed without sodden instability. For some comfort is an ocean liner with absolute no feel or sound of the surrounding world. But none of the ocean liners want to be in a situation where you have to do a moose test on highway speed. This is why all the cars built in the last 10 years come with low profile tires and till the mileage is ok and the suspension is good they are comfy.
Its a bad misconception that low profile tires make the car a bad ride, it makes the suspension work more and if that is crappy in doing that, than its flaws will be more obvious.
I disagree, the X type I have just purchased came with 18ālow profile tyres and the ride is very un-jaguarish, quite harsh in fact compared to my XJR on 18ā which the suspension was designed for
