XK140 FHC Plywood floor thickness ?
Can’t seem to find a conclusive answer . Does anyone have a pattern or measurement for these ?
140 explored only shows dimensions for OTS and DHC.
Thanks Jim
An original piece from my 120 FHC measures exactly 3/8 inch and is 7 ply.
I think you can only get metric thicknesses any more so figure 9 mm.
Hi Jim
These floorboards were on my 140 FHC when I got the car.
They were not the original ones, but I used them as templates for new ones I cut in 10mm marine plywood, which were a good fit.
Jack hole covers were missing, but finding their position and cutting them is not a problem.
If they can be of any use to you, you are welcome.
Francis
obviously not original floors but note the new ones have had some of the old alli cappings transferred over that run along side gearbox - to stop oil getting into ply I guess?
Thank you Fellas for the info .
I managed to get a look at a 140FHC today that had no carpets in so I could get a good look at the shape , they don’t look to complicated to reproduce .
Jim
I have an admission to make . I forgot that I actually have my old floors stored an forgot I had them . I presume they are original as they have the ally trim along the tunnel . They are badly de-laminated , but measuring the ally strip I guess the wood is 9/10 mm thick .
Jim
