PM4 9 position wiring connector - can’t find on google
I’m trying to find a PM4 9 position wiring connector. This is for a custom subharness that I want to plug into the original harness. Here is a photo of manual, the plug itself, and a gratuitous photo of PDU diagram.
Post a wanted add in the classifieds
Looking for a supplier of a new one. I’m just not googling it right! It has to have another name, or is buried in some online catalog.
This is very close, but it’s smaller than the 9 position unit I need
this one has 9 pins, but looks slightly different for the pin locations
Do you have a manufacturer’s name for the connectors or the equipment?
That might help.
Possibly AMP, which was bought out by Tyco, renamed TE Connectivity. The series is Lock N Mate
But I gave up. Just bought a generic connector off Amazon and will dike it off. Only 8 of the nine positions were used so this 8 pin should be fine. The important thing to be was for it not to be a pigtail.
Well thats your concours out the window :rofl:
I’m fairly certain the connector and the pins are no longer available. I ran into the same issue and Paul Kobres responded:
For my car I just used two weather pack connectors (flip flopped so they can only be attached correctly).
For another harness I did something similar but basically a dongle so the recipient could just plug-n-play.
The TE Connectivity diagram and PNs for the connector are here.
Relevant thread post:
TE I think sold out to Aptive? But at least the data sheet links still seem to work.
~Paul K.
Thank you for this information. I gave up and cut it off. You wouldn’t do that to an XJR-S!
