Eric,
Thanks for this photo as well as the ones you’ve posted on the parallel thread regarding hose routing. They have all been highly instructive.
I spent about 5 hours on my a/c system today, and want to show you what my setup looks like so far.
First, going back to 2020, the shop that did all of my sheet metal repair/replacement also did a lot of prep for the future a/c system: they cut the hole through the firewall for the hoses and carved out the space for the evaporator motor above the passenger’s knees. As part of the job, they also welded a mounting bracket for the alternator onto the driver’s side motor mount (viewed from above in the photo). Note how close it is to the steering shaft.
Fast forward to 5/8/21. Mounted onto that bracket, the alternator was quite close to the steering shaft, so we had to carve off some of the metal from the alternator casing. It wasn’t a full “de-earring” but we had to shape some new curves in the case. We also gained a bit more clearance over the steering shaft by putting one washer under the engine mounting block to shim it (and thus the attached alternator bracket) up slightly.
We made more progress this afternoon (5/15). First, the compressor. You’ll see that the compressor’s rear ear closest to the engine is bolted to a bracket mounted on the front-most exhaust manifold studs. The front ear closest to the engine is mounted to the RetroAir timing cover bracket (that’s more visible in a later photo). The front ear further from the engine is attached to the engine bracket via an adjustable rod.
Here’s a rear view of the compressor, with the alternator below. Note that the bolt securing the rear of the alternator runs (front to back) through the lower mounting yoke of the alternator, then through a black spacer, then through the mounting bracket welded onto the engine mount, and is finally secured by a locknut.
Taking the top view, you can see the two-belt arrangement. One belt runs around the crank pulley and the compressor. The other runs around the alternator, water pump pulley and crank pulley. No idlers anywhere. We were able to tension the belts and they did not foul each other nor did they foul anything else.
We’re now moving on to setting up the condensor, receiver/drier, evaporator, hoses and heat shielding.
Thanks again.
Bob
