Good Day,
Does anyone know how to remove a power seat in a 2006 XKR when the motor will not move the seat forward and backward at all. The motor is getting power so it’s not a fuse problem. Is there a way to make the seat “freewheel”?
Thanks Devon
Good Day,
Thanks Devon
Easiest way is to swap the seat modules over and try that. I don’t believe there is a way to manually move it.
Jim.
Thanks Jim, are the seat modules under the seat?
Feel under the front of the seat base and you’ll find them. 10 mm spanner if I recall correctly. Lower it, disconnect it and then swap over.
It’s also worth having a look inside to make sure there is no obvious damage. It is a known fault of tracks burning out but they can be repaired with a bridging wire.
Jim
