This guy makes oil filters for the 1� litre Jaguar. He has both the
corrugated felt type and the paper element type. http://www.daimlerspares.org/index.html
It looks like there might also be a source from Mercedes!
Peter
philmac wrote:> Would appreciate part No or whatever to enable me to purchase an
In reply to a message from philmac sent Sat 28 Sep 2013:
If as I suspect 1/2 litre filter elements are the same as the 6
cylinder cars, you should try a local { Aust] Ryco filter RP 205
from memory.
. They were making them specifically for MK IV/ Vs with the large
square section seal included in the kit
Although the element also fits other later Jaguars, they don’t use
the larger seal.
The later smaller seals are not much use for Mk IVs.
You may still find them around in Aust but are no longer made
after Ryco moved its manufacturing to Sth Africa.
Other wise if you’re in Melbourne you could drop over and pick
one up here, or Rob Reilly had a place in US that sold square
section seals of the right size.–
insert for 1.5L oil filter
If it is common with any other applications, that info would be good
In reply to a message from Ed Nantes sent Sun 29 Sep 2013:
The source I have used for sealing rings is McMaster-Carr www.mcmaster.com click ‘‘sealing’’ then ‘‘o-rings’’ then scroll
down to choose square cross section and you get their list
of sizes, a package of 10 or 25 will last you awhile, or you
can buy cord stock and make your size with cyanoacrylate
super glue.
I still have my notes from when I was searching filters for
the XK120 and Mark V. Assuming the 1.5 filter is similar to
the Mark V and fits in a canister with a centering
arrangement inside. Let me know the ID of the canister,
minimum ID the filter or OD of the centering part, and min
and max overall length. Some of the filter makers like
Hastings have size search engines.
You want the filter to be a little bit smaller than the ID
of the canister so oil will flow around it and through.–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
