It seemed easier for me to draw stuff in Photoshop before
starting to cut the felt and especially before applying the
bitum based sound deadening to replace Mutocel.
So here I have a bunch of photos from my car when I have
drawn various bits and pieces.
I remember that there were indeed many small errors in the
MKV parts book, but some of these are really confusing and
take a lot of interpretation:
The Saloon part is much more descriptive, maybe this is
because they didn’t provide as many pictures as for the DHC.
(Saloon body = 1 plate, DHC body = 2 plates)
Most of the felt and Mutocel parts listed on page 77 (Saloon
Body Fittings) can be found on pages 105 and 106 (Body And
Fittings, Mark V Coupe Only) and the ones for the rear seat
may indeed be a bit different, but I think the ones for the
floor should be identical and the floor pressings are identical.
- BD.2429 Felt in depressions at Rear of Floor 2 pcs (Saloon)
BD.2429 Felt (Disc) 4 pcs (Coup�)
I think 4 is the right number as these are for the two fake
and two real floor mounts. Or then the ones with the bolts
did not have a felt disc in the beginning.
- BD.2443 Felt, under Carpet for Clutch Housing Cover 1 pcs
(Saloon)
BD.2443 Felt for Clutch Housing 2 pcs (Coup�)
Surely only one piece?
But then there’s also BD.3127 Felt for end of Gearbox Cover
2 pcs (Coup�) but surely this was only one and also used in
Saloons? As BD.2458 Felt, under Carpet for Gearbox Cover is
the same 1 pcs for both.
- Then there’s a big bunch of felt on page 106, especially
BD.5201-BD.5206 that do not appear for the Saloon. Lucklily
the have provided the sizes so I’m going to cut those out of
cardboard and see where they could fit (!?!) I’ll of course
report back here.
Did some of these replace earlier ones? (no numbers or
explanations to be found in this book) as BD.5201 Felt,
Floor depressions (7 1/2’’ x 5 1/4’’) could be replacement for
either BD.2425 or BD.2426. The large ‘‘Cushion Roll’’ (51’’ x
14 1/2’’) BD.5203 and BD.5204 and BD.5205 ‘‘Pedal boards’’ (2
pcs of each) as well as BD.5206 Felt, Gearbox Cowl, Inner
(16 1/2’’ x 9 1/2’’) seem really strange…’‘inner’’ to what?
Inside the cabin or inside the Gearbox Cowl?
I think most of these are due to the Saloon being ready for
production first and some things were either changed later
(and for the coup�) or left out of the books first edition
due to haste.
Please feel free to comment what you have found and
especially anything concerning the size on the the Mutocel
‘‘parts’’ and if there was any on the toeboards or not, as
well as he amount of felts used in some areas.
Cheers,
Pekka T. - 647194
http://www.jag-lovers.org/v.htm?1232796235--
MKV 3.5L DHC, E-type 2+2 Ser.1 MOD, XJ6C MOD, XJ8 Executive
