Hi all,
This came up with the floors and some other panels on my
MKV. The RH door, panel behind rear seat, rear quarter
panels, some parts of the scuttle have their original sound
damping (although I would think they don’t dampen that much
anymore, they seem quite hard) ‘‘Mutocel’’ pieces which give
good reference.
But the problem is this, IME the sound dampening stuff has
always been fitted on the inside, that is the passenger area
of the car, not on the outside. Also my E-type and S2 XJ6C
have things very much in the same manner, but on the MKV DHC
for instance there is Mutocel on the outer side of the rear
seat panel, that is in the luggage compartment (boot) side.
Well that is still inside and not under the body.
The big question is that as the parts book (coup� pg. 106,
saloon pg. 77) lists ''BD.2454 Mutocel for Front floor (2
pcs), BD.2455 Mutocel for Rear floor, BD.2456 Mutocel for
Clutch Housing Cover (2 pcs) and BD.2457 Mutocel for Gearbox
Cover (2 pcs) where and how should these be fitted???
I have not found any trace of Mutocel on the front or rear
floors and I have not yet pulled the carpet off the gearbox
cover, but am puzzled about if this should really be fitted
between the steel panel and felt and if so, in which places
and patterns? On the E-type and XJ S2 there are parts of the
floor panels that have this similar material under the felt.
I have a pretty good picture now how the felt pieces should
be cut and fitted onto the floor.
It seems strange that the seat rails are really mounted on
top of two layers of felt and one carpet, and on the outer
side a moquette covered piece of plywood, but I believe that
is the way it should be…well the floor is also sort of
flexible anyway, I think they had problems with these seat
mountings in then past also. On the E, the seats are really
well fixed onto the body with steel brackets and metal
distance tubes that the bolts pass through. Well I will make
sure the floor is solid enough and straight in the seat
mounts, I have already used some POR patch and a few strips
of glassfiber in places where the were cracks in the
floorpan and pinhols of rust.
I can think there was a piece of Mutocel on the toeboard
part of the scuttle/front floor, but especially the front
and rear floor I can’t figure out or understand where it
should go. Are there any pictures anywhere that would show
this? Rob?
Cheers,
Pekka T. - 647194–
MKV 3.5L DHC, E-type 2+2 Ser.1 MOD, XJ6C MOD, XJ8 Executive
