can any body advise with 3.5 litre mk4 the rear shock absorber
linkage arms that is the dog bone joining the shock absorber arm
and th chassis what are the correct bushes for these two ends
when dissasembling I noticed the top rubber appeared to be bonded
to the bolt is this coorrect and the bottom near chassis bush had
a mtal tube inside the rubber bush what is correct and has any
body heard of urethane being used inthese bushes ideas please peter–
big4
In reply to a message from big4 sent Tue 25 Nov 2014:
There may have been some variation
But the main ones I’ve seen are just a rod with a tube each
end, Formed as one piece but easily fabricated
There is a pin in the centre of the rubber which is threaded
for mounting.
We use local Ford Falcon shocker rubbers. They have a flange
which is easily cut off
It’s a trick to install them I find it easiest to drill the
end of the pin for ,say, 1/4’’ Whit thread .
Then we turn up a bullet shaped guide to insert into this
thread, This will lead the pin into the rubber without so
easily] pushing the rubber out of the tube.
You will need rubber grease [ or KY jell if so inclined: >)
We put them in the vice to push them in and it becomes a
trial and error job. Pushing the pin into the rubber at the
same time as the rubber is being pushed into the tube.
The rear are hardest to get at. YOU’ll possibly have to remove
the backing plates or at least hopefullly have access to a 4
post hoist
The MK IV chassis is not really suitd to a 2 post hoist.
I certainly would not use urethane on these [ or wishbones on
Jaguars .–
Ed Nantes SS
Melbourne, Australia
for mounting.
post hoist
Jaguars .–
Ed Nantes SS
