[quote=“Kim, post:21, topic:426006, full:true”]
Is there a case to be made for replacing the fuel pressure regulator that is not leaking, based on too high of a pressure?
As Doug says, Kim; certainly - but the regulator seldom fails in this way. Which doesn’t mean it cannot happen…
[quote]
30psi on the fuel pressure. It does run better and the new plugs are not as sooty
[unquote]
At 30 psi and 18" Hg manifold vacuum, the engine should really run perfectly…
Frank
xj6 85 Sov Europe (UK/NZ)
