A DIY rebuild of a TH400 is a very possible thing. One important thing to think about is to have the transmission coolant lines flushed out as any clutch debris gets collected there, and can mess up a new rebuild. This also means the Torque Converter needs to be replaced when rebuilding because it can’t be cleaned out w/o being cut open and rebuilt. JA4 is a common ref number w/6 lugs, but the 3 lug versions will work. A common 6 lug big block high stall converter would work fine too.
I am a bit confused here…
As stated from Josep, the trans works on R, 1st and 2nd, but not on D…
When on D and stationary the gearbox is on 1st gear. What changes…?
Rear band is only difference between drive position first and manual first. Low gear one-way roller clutch is active in manual low and drive first gear; rear band also applies in manual low (but not drive)- I am GUESSING the one way clutch is NFG (if symptoms are accurately described).
I second your vote. I’ve tried extra fluid changes, and expensive additives to try to ‘save’ a bad transmission. About all it did was buy me a week or two.
Could you confirm if the TM400 ZV A is compatible to the jaguar xjs v12 5.3?
I see this on internet with warranty. I asked to rebuilt my gesrbox but in Spain is not an usually model and its difficult to find a mechanic with knowledge.
Internally the bits are likely close enough, but that case looks different. Jaguar had their own case/bolt pattern. The pattern in your photo is hard to see, but yours doesn’t look quite right, different shaped bolt hole bosses and a missing flange. Plus that big cast “24” on top I’ve not seen before on Jaguar version of TH400.
Everything I’ve found searching here and on Google says a ZVA trans is for the Jag 5.3 V12. The other tell is the 6 lug torque converter. A lot of GM applications used a 3 lug. If i was home, I’d walk out to my garage and look at the trans I took out of my manual conversion. I should be home Wednesday, if you can wait.
I see a great big 24 cast in, disproving my theories
Kirbert
36
So the one in Josep’s post above looks correct. Note that it’s rolled a bit to its right, you’re not looking at TDC but rather the top left area of the housing.
Looks like you’ve got your answer, but you could always do a large-format printout of the flange representation I put up at GrabCad and physically compare it if you needed to:
