I am looking for an original E-type 3.8 radiator. Perhaps you’ve replaced your radiator with a modern, more efficient one. If you still have the original and would like to sell it, I am interested.
Al Jacobson
Hi Al - We have an original radiator for a Ser1, 1964 3.8 E. Very good condition, never overheated, comes with fan cowl and drain tap (spigot). Asking $500 plus shipping. We have a lot of other original parts for the 3.8 also.
Bruce and Lois
Bend, OR
FYI. The original 3.8 E-Type radiator cannot be rebuilt or repaired. It’s a stacked plate design, the construction is more like an oil cooler than a radiator. This means that the “tanks” are integral with the “tubes”. Because the tanks can’t be separated, it can’t be recored or rodded out by a radiator shop. If it leaks, it can’t be soldered because of the aluminum construction, and even if welding is successful, it results in an ugly scar. If a chemical flush can’t clear it out, then the radiator is done.
It’s my understanding that all 3.8 liter E-types were fitted with an aluminum Marston Excelsior radiator. The switch-over to a brass radiator happened in late 1964 when 4.2 liter production commenced.
A Marston is easily recognized by its aluminum fins:
Replica Marston radiators are generally available from a few sources, mostly in the U.K.
The radiator in Lois’s photo is a later style brass radiator, Lopena’s photo is an original Marston stacked plate radiator. There’s always been a question of whether the brass radiators were replacements or factory original. Because the stacked plate design wasn’t intended to be repaired, a great many of them were discarded through the years and replaced with brass. So the question is difficult to answer today.
The stacked plate radiators are the ones to which I was referring earlier. I make reproductions of these in the US. But there is nothing made anywhere today that is an exact copy of the original, due to the extraordinary expense of tooling the plates and the obsolete brazing process that was used. All of the repro’s available today are made with conventional cores and machined tanks.
Hi Paul, I have one from a car I purchased a few years ago that’s in the garage attic. I’ll take a look at the condition and let you know later this evening.
Garth…
Great Al - we will get the shipping cost tomorrow, Tuesday… USPostOffice will probably be the cheapest, but if you prefer UPS, we can do that too. Where are you located? Money Order or PayPal is best for payment.
Thanks Al,
Your fellow Jag-lovers, Lois and Bruce Ross
Bend, OR
