Is there not enuff room for a push auxiliary fan in front of radiator?..
Not in the original configuration. Far too many obstructions in front of the rads.
IIRC, there is a diagonal brace across the front of the rad that would make it difficult to fit any reasonable configuration of pusher fans in there. However, the brace is simply bolted in. Presumably you could unbolt it and replace it with a homemade brace that would facilitate the installation of pusher fans.
