the 2001 i bought the engine bay is really dirty. i did cleaner and water on my 2004 xtype, and moisture settled in around the coil paks, caused a problem for few days. thankyou for any advice to clean it.
mike
Thanks for posting that TSB, Motorupman. btw, you seem to be posting more frequently of late ⌠hopefully that means youâre getting close to fully âmendedâ?
I have good dexterity of the right hand but lack strength/grip after my stroke.
I am back to typing with both my index fingers so Iâm OK with that.(I hit what I aim for instead of the âtoddler wobbleâ I had a few months ago)
I can work the mouse as normal now.
Very good, Motor ⌠Well, some weight or Isometric work should help you with the strength issue ⌠Did they advise you try something like squeezing a small hard rubber ball in your palm and holding it for a 10-count? Bodybuilders/weightlifters also have those things that look like a nutcracker that has a spring-loaded tension in it - you squeeze the two handles together in your hand as tightly as you can and hold for 10 as well.
Hereâs the ticket:
YESIMET Hand Grip Strengthener Set, Finger Gripper, Hand Grippers - Soft Foam Hand Exerciser for Quickly Increasing Wrist Forearm and Finger Strength, 2 Pack
Color:blue
(available on Amazon)
I went to therapy for a while and was given a rubber ball for âsqueezingâ.
Just going to take a while.
