let out the pic …just to challenge y’all
I have this saved as the hardware that goes through the bonnet nose mount into the trapeze. Is this correct? It doesn’t seem as though there would be an internal tooth or split tooth washer between the steel insert of the nose mount (as shown) and the trapeze section?
Bill,
The Jaguar Parts List indicates a spring washer FG.106/X on the pivot bolt. The Shakeproof Washer in your photo looks like C.725, one of which is supposed to be fitted to each of the 8 bolts that secure the hinges to the bonnet.
-David
thanks will work on that
