I have just installed a new wiring harness in my1964 MKII and I have a question to those of you that have running MKII and they are…
1/
on the starter solenoid in the engine compartment how many brown wires are on the outer most terminal, I have three wires I put two on the outer terminal as they were joined an one on the inner terminal, BUT as far as I am aware only the starter cable should be on the inner terminal, therefore I assume all three brown wires should be on the outer terminal ?
2/
on the base of the B post harness I have a Red and green wire ; on ‘Both sides’ which I believe on my RHD car goes to the handbrake switch but not sure where the one on the other side should go to.
3/
And this one is fun just in front of the heater box there is a pair of red wires that are joined and I have no clue what they are meant to do , DO YOU ?
Thanks in advance for all your help.
