The manual says 2 ways to check auto trans fluid- Yes warm & running but - it illustrates unbolting the tube and sliding it away from engine to check level and another illustration shows just to check where it is- - HELP?
1996 XJR6 supercharged
Hi, I think that is only for cars that have an EGR valve ( page 29 of the vehicle care book). If you look carefully at the illustration it shows a sliding bracket which certainly our 1996 xjr doesn’t have. So in essence ignore the unbolting and sliding stuff and just check the fluid hot after a run of 10 miles/16 kilometres.
Thank you - all seems to be good
