All,
Do any of you have a radio delete in your XJ?
If you do can you take a picture and post it for me?
The parts I am interested in are BD. 34607 and BD. 17354. Below is a picture of the assembly manual showing these parts.
Thanks!
All,
Thanks!
“radio delete” is an American term. Try “blanking plate” and you’ll get results like this:
Thanks John!
Search terms are key when searching the world.
By chance, when you search for a part number do you use the BD and do you use a space between the letter and the numbers?
Thanks.
Search for all combinations! There’s a few obscure Jaguar tools I’ve found that sellers sometimes list as JD.### JD### JD ### and I have saved eBay searches for all variations.
Now for a semi-related Corona boredom tangent…
“Professionally” as programmer, when something stumps us we rarely ask a coworker how to do it… we ask what we should google to find the answer. “I need a select statement to do DML via a function”. Oh go google a pragma autonomous_transaction… Can’t google it with out those magic words!
There’s an old white haired guy who comes into the office a couple times a week and his only job is to water the plants. He never says a word. Didn’t hear him speak for the first five years I was there. Exactly the kind of reserved personality you’d expect from a professional plant water-er. I can’t remember what what it was exactly but we were trying to talk through some technical problem and said some obscure technical words and he peers over the cube walls (he’s on a ladder watering our plants) and says “I imagine it’s English, but I’ve never before heard any of the words you just said”.
Yeah, so, blanking plate.
I wanted to add more to this post in case anyone else is interested in this option…or lack of option.
I looked through the brochures I have for Series 2 cars and found an interesting trend. All the pictures of the XJC’s had the radio blanking plate, while XJ’s (both 12 and 6) had a radio in the picture. I am not sure if this was planned or just coincidence.
Here are some pics of the brochures:
If anyone has this option in their car, please add a photo to this thread!
Thanks
pic of 1978 XJS updated dash, Burlwood epoxy overlay! ,
I have the blanking plate in my 72 Series 1. I’ll try and post a picture tomorrow.
Jeff H.
@ronbros did you cut out holes in the burlwood overlay for the temperature and fan settings to be visible?
If so, what a fantastic level of detail!
@jahmiata and @davidsxj6
What material does the black vinyl attach to (part BD34607)? Is it metal, cardboard, or some other material? Is it attached with glue or staples?
It looks like there are a few businesses that carry the actual metal blanking plate (BD17354), but I have not found anyone who supplies the vinyl piece.
Thanks for sharing the pictures!
If you look at the technical drawing, it must be made of metal, so my guess is that if you cut a steel, brass, stiff enough plate to shape, round off the corners a bit and insert (solder? peen?) two flat head carriage bolts or similar in, you can glue the vinyl into place and be done in an afternoon for a few $ as long as you found the right vinyl structure and a bit of backing so the bolts don’t show.
I have no idea if the plate feels soft or how deep it is. My photo is from Lyons‘ personal Series 1 that lives in the UK.
Harry,
as for your original question: it looks like there’s no method behind the fact that coupé catalogues sport the blanking plate while sedan catalogues picture a radio. The early SII catalogue “The Jaguar XJ range” has two pics of the pertinent part of the interior and both have no radio, but the blanking plate instead.
The blanking plate for SII cars seems a bit higher than the one for SI cars. As their mounting was for the two-axle cut out usual in the days I’m afraid the original blanking plate wouldn’t cover the gap, if your heating cover was cut out to accommodate a DIN radio at some point in time. Then you’d either have to find an unmolested control panel or fabricate a slightly larger blanking plate.
I’d be confident to make up the vinyl cover using some padding and contact glue and use some rubber cover for the pins to make a friction fit of the vinyl part, but the rear part (BD.17354) looks like it was chromed. As you’ll see only the edges the finish of the plate fabricated from aluminium or stainless should be near perfect.
All in all I’d probably use a cheap tin plate and make the vinyl cover slightly larger to hide away the tin plate - not original, but certainly good looking.
Good luck
Jochen
75 XJ6L 4.2 auto (UK spec)
Perhaps late to the party, but I found the blanking plate that came with my 1974 S2. If someone has any idea what the other parts in picture are, I would be interested in knowing. To be honest I do not even know if they belong to the car, but they were in the same box
/Marc
Marc that silver ‘y’ shaped tool appears to be the spanner for loosening the disc retainer on a harbor freight 4" angle grinder or similar and the brush-with-spring and box also look like they’re spares from the same tool. Not sure what the black thing is.
~Mike
Thank you Mike!
That would make some sense.
/Marc
Black thing looks like guide for a skill saw
