Any opinions on replacing the large end radius bushing with a polyurethane one such as this?
https://www.sngbarratt.com/us/#!/English/parts/aad49ca3-6acd-4ee2-9a38-fc89e266c4b7
Should be OK, depending on the equivalent shore hardness you might find there is an increase in the transmitted road noise.
The grease when installed eventually leaves & they will squeak and as said they are a harsh ride. Mine pulled apart every when I jacked the car up. I made stainless covers & tacked welded to the bottom to the arm. Works great. No I wouldn’t install them again, go with the stock bush
Thanks, I will stay with the stock, and delay the spend.
