I bought a new rear door seal part number BD23347
. It is all one piece. Which way up does it go in the body groove and should the join be at the bottom?. The old seal which is still on the car is probably the original one and does not have the cross section shown in the photo but it suggests that the Vee shaped end shown in the photo faces outward.
The larger lip, what you have in your photo on top is the side that faces up. The âflatâ gets glued down in the âgutterâ. The âopenâ side faces to the inside of the hatch opening. If you need a photo, Iâll send one. I just installed this on my 69 FHC
MY BAD⌠wrong ! The OPEN side of the seal faces out⌠that way the seal acts like a gutter keeping the water/rain out of the car. Sorry, addled from being under the car all afternoonâŚ
Iâd like to see a pic of your install please. Thanks
Let me get this straight. The seal is âUâ shaped with a âVâ shape on the bottom of the âUâ. You are saying that the âVâ shape is glued in the grove in the body and the top of the âUâ faces up ( what you call the open side) and comes in contact with the hatch door when you close it. Thatâs the same as the seal on the rear of the passenger and driverâs doors. The join is centrally positioned at the bottom of the door âŚright?
Itâs a little strange that the seal on the car at the moment looks nothing like the new one and I wonder why
Stuart
So my view is the flat/V shaped piece goes against the vertical edge of the metal, and that leaves the piece with the shaved edge sitting down in the gutter, leaving the curved rounded section to engage with the gate when it closes.
Thatâs how I have it on my car.
Correct or not here is how I have the weatherstrip on my car. Note the cutout for the drain in the first picture. The two ends meet at the latch.
Sorry but I am getting more confused. Is this right?
No: the side thatâs mainly flat, that you have labeled âtouching the hatchâ, is the one that gets glued into the channel. The U shaped part faces out like an awning.
So this is different to the photos that John Walker provided. So the two sides of the âUâ contact the hatch door. RIght?
Just the rounded part, that is shown on the left upper side of your picture.
I have the same issue. It is still not clear to me.If i have the U shape facing outside the rubber is clearly visable when the door is closed.
Do i do things wrong .a picture how to do it would be great!
Rgds Ron
Mmm mine is flat on bottom and pointing outwards too and it doesnât leak or get exposed to environment when door is closed
