Can anyone tell me the size of the rear welch plug above the bell housing on an XK140 engine?
I know the side ones are 1-3/4", but the rear one is larger.
Thanks,
–Gary
Thanks,
–Gary
It should be the same size.
You’re correct. I knew there was one plug of a different size but it’s on the RH side, not the rear.
Thanks,
–Gary
1", IIRC. The plug seals the passage where the oil drains from the rear of the head back to the sump so no pressure behind it.
