Rebuilt, broken-in Series 1 Engine plus choice of gearbox.
Engine number 7E 53988-9 casting date Feb 67 removed from later non-matching 1970 FHC .
Not built by me but a good engine with at least 1,000 miles by me. Everything I’ve checked was fresh - although apart from top end and borescope only ancillaries etc. checked. Has had new water pump, new clutch and new semi-lightened flywheel, gaskets, core plugs etc. Ran well, fitted with the 1970 Stromberg carbs with removed secondary throttle plates. Comes with either air cleaner for use in later Series 2 E-type, or optional early S2 triangle plenum system with S1 air filter cannister, both with new elements.
Was fitted with air conditioning pulleys but replaced with S1 style. 1970 distributor still fitted. Could supply non-emissions distributor or XJ6 electronic ignition if wanted
[Engine]$6500
Optional bell and near-new clutch plus short or long all-synchro 4-speed gearbox and propshaft to suit either OTS/FHC or 2+2 6 cylinder E-types (engine and long box could be used in XJ6 etc.)
[Drive train] $2500
Contact information: 910-398-3620
Call or private message to discuss your preferred package.
