I fabbed and installed remote bleeders four or so years ago.
This is the sequence I posted on J-L back then:
- Two brass brake tees, each wired brushed at one end to prep for soldering
- wire brush and tin about 1" of 3-8x UNF 24 threaded rod stock
- cut the tinned rod stock to make a plug
- apply flux to both ends of plug and screw into connectors
- clamp assembly in vice to align and solder together
- file excess solder smooth
screw in bleed nipples and attach to angle iron mount
remote bleeders in place with cunifer feed pipes
While I prefer the remotes I but found them more difficult to bleed:
