Working on the passenger door as we had already done the drivers door weatherstripping. It is imperative, and yes it really sucks, to have to remove the entire door on a MK2 to replace the rubber door bits. Using a floor jack, music, refreshments and a lot of tears. we found that it took us over seven hours to do just the one door.
There is a floating captive plate within the door that you have to bolt 6 bolts into which hold the door on to the car. Do NOT mess with the four Pozi screws as you will go nowhere!
With the help of someone with VERY small hands; I had the beautiful Angela, you need to hold the captive plate steady and then push the six bolts through the hinge, into the door and into the captive plate which is constantly wiggling.
Once you have every bolt semi tight then the fun begins as you use a rubber mallet to convince the hinge back into the factory position by observing the rust lines! Gently shutting the door numerous times will allow you to use a floor jack to raise the entire door into position, re tighten the nuts and do this about four times until you get that famous Jaguar door thump.
This proves that Jaguar in Coventry hired people with miniature hands to do another task on their assembly lines.
Having this all completed I took the beast out for a romp up to 80MPH and somehow it is almost OK… More driving, more exhaust roar and everything will be OK. But wait, we still have the rear door to complete…
Gerard
Loveland, Colorado
