I need to remove the manual overdrive transmission on my 4.2 Series 1 to switch the overdrive for another unit. When I did the conversion to manual I obviously installed engine and trans as a unit from the top.
I know that the various Jag books advise always removing them together on S1 but is it worth trying to pull the trans from below? The problem I see is the starter bump in the bellhousing fouling the trans tunnel and making it hard to re-install and align the input shaft if I get it out. Looks like no room to pull back without tilting the engine considerably
Anyone have any first-hand experience with doing this?
BTW I’ve pulled transmissions from below dozens of times on other cars and have the necessary jack(s) and other equipment. I just don’t wanna do it like that if it’s gonna be a major problem. Not an emergency if the O/D doesn’t work right now.
~Mike
