On my XK 120 OTS 1954 I need to repair the wooden frames in the rear door. Some pieces of wood are too much broken.
But the ALU cover is still ok. How can I take out the wood frame without damaging the ALU cover at the edges.
Does anyone of you have experience in this?
I had the same problem in replacing the ash boot lid frame I purchased from RS in the UK. The edge originally turned over the steel surround has to be bent back up. To avoid deforming or cracking the edge of the aluminum skin you must anneal the metal all around. Once annealed the edge can easily be pried up enough to remove the old wood frame. If possible, it is best to screw the original steel surround band to the new wood before refitting.
Gery,
Initial photo is of a boot lid from a 1950 alloy roadster similar but different than a later steel car shown below.
If wood and lip are missing, probably best to purchase a replacement.
Thank you all
Now I’m whit you. My wood frame is correct.
However, a piece of the sheet metal covering on the wood frame is missing.
I have to make that.
The rest I have to prepare.
