I just replaced the radiator in my 2000 XK8 with an after market unit. Every thing has gone smoothly up until now. There is no expansion tank breather connection to my radiator on my particular car. The fitting on the ex. tank and the radiator appear to have been plugged at the factory. However, my replacement radiator fitting is NOT plugged.
Any suggestions on what method or material I should use to plug it. I can think of several, but they are a bit amateurish.
Thanks!
Michael,
Earlier versions of the XK8 had a hose connection from the left side of the radiator to the coolant expansion tank. Later models deleted this feature. First, verify that the barb connection on the new radiator is actually open to the coolant. I replaced a radiator an XK8 radiator a few years ago. The new replacement had the barb but it wasn’t functional, similar to the later expansion tanks. If yours is open, you have a couple of options. 1) Install a cap onyo the 3/8" barb fitting on the radiator. If you have an Autozone near by, look for part number 47395. It’s a 3/8" ID rubber cap made by Dorman. Install it onto the radiator barb with a hose clamp. 2) Modify the solid barb on the expansion tank by carefully drilling it out. Install a coolant grade hose between the radiator and the expansion tank.
