Anyone have info on replacing headlights on 2005 Jaguar XJ8L?
Low beam adjusters are both broken . Am told there is no fix for this other than replacement of the whole unit .
Is total replacement of the Headlights the only way to correct this problem .
Kim R
2012 XK Convertible
2005 XJ8L
Are the lights HID??
There is a ‘screw’ fix for the regular Halogen to lock the unit in place once the headlamps are aimed correctly.
Drill a hole and insert a LONG threaded wood or sheet metal screw to lock the inner to the outer housings.
Plenty of info about this ‘work-around’ repair on the internet.
HID needs to be moveable for auto leveling feature.
bob
