Has anyone used the standard motors ry1056 relay for an over volts relay? The dbc4292
Take the cover off and see if the solder joints are cracked.
Resolder if they are cracked.
Check the small glass fuse to see if it is ‘blown’
The relay is basically a ‘crowbar’ type circuit with a zener diode to blow the fuse and disconnect power if the voltage exceeds a threshold to save the module.
I have soldered dozens of relays and replaced a few fuses but only replaced a handful of relays that could not be easily repaired.
bob
David,
Surprisingly (or perhaps not so surprising considering the price asked!) Jaguar apparently still have those ABS over-voltage relays available - item 5 in this illustration.
If all else fails, I guess that is an option?
Found a new relay at Barrett US, $38, popped it in and abs fault is gone! Hurray, now on to the bulb failure, can’t find any not working though.
