Been having one heck of a hard time getting the metal ferrule (think “foreskin” ) to retract back on the door handle of the driver’s door of Superblue so I can access the screw behind it in order to remove the door panel. I tried spraying the handle with lubricant and yanking on the ferrule with large channel-lock pliers, prying a big screwdriver (slot) tip under it, etc. but it will only budge enough that I can see the screw, but not enough to be able to access it with anything for removal.
Any suggestions for getting the ferrule to slide further back? I’d hate to cut up the leather on the handle (which is already scuffed up from apparently the PO retracting it before) or have to try to cut the ferrule off with a mini saw.
