Hello,
I was visiting my local Jag mechanic, and he was stumped with a stuck FR drive shaft that will not come out.
If anyone has any ideas, I’m sure the mechanic, and the car owner would be happy.
Thanks,
Rob
Hello,
Thanks,
Rob
The RIGHT axle link shaft should NOT be removed until the retaining clip on the end is removed. (after the transfer case is removed)
This an excerpt from page 14 of the TSB XT307-S941.
CAUTION: THE TRANSFER CASE LINK SHAFT SHOULD ONLY BE EXTRACTED BY A MAXIMUM OF 200 MILLIMETER OR DAMAGE WILL OCCUR TO THE INTERNAL SEAL.
The CV joint can be removed but the AXLE LINK SHAFT needs to STAY in the case.
The TSB has info for removal of the gearbox but a few pages have info on the axles.
XT307-S941 JATCO JF506E Transmission Replacement.pdf (1.5 MB)
Mr. Motorcarman, you are THE Man!
For years you have given so much to these forums.
As my Dad would say; “your halo is showing”.
Thanks so much.
I forwarded your response to the mechanic and he is grateful.
Rob
