Asking for a friend. No seriously. My buddy down the street has a 66 OTS that he recently did a full engine and drive train restoration on. I’ve been helping for laughs and giggles, all this past spring and summer. The car is stunning.
This is running on stock distributer, points, condenser, etc., with triple SUs, naturally. The carbs and distributer were sent to a couple of the recommended big boys for full R&R.
Shortly after we got it running, we checked the points, timing etc., and tuned the carbs by the book. The car has been running fine all summer, and only has 100 miles on it.
Suddenly, there is a hesitation on acceleration. It does not happen when the car is stationary, ie, blipping the throttle in the garage. We checked the timing again at 10 degrees BTDC, and it was spot on. We checked the distributer wires by attaching the timing light to each high tension lead in succession and found #2 was spotty (he did not change the leads in the resto). We tightened it up, went for a test run, and the problem was still there.
We pulled the plugs and they were extremely fouled, indicating way too rich. And yet, the exhaust note is extremely stable and we’re getting no blue smoke.
So the question is, how can the carbs “suddenly” be running very rich after only 100 miles? We’re ready to tear into them, but it just doesn’t seem right to me.
In searching the JL site, possible culprits for the lope are:
- Timing
- SP/Distributor wires
- Carbs
- Faulty condenser
Item 3 can cause the lope via rich running. But, again, at idle the exhaust note seems perfect.
How about item 4, the condenser? If so, by logical deduction, does this sound like a bad (new) condenser? My buddy doesn’t think so. He wants to change the wires and retune the carbs.
Any insight?
