Hi .My jaguar has rust underneath … and I would like to remove it. How do I do it myself? and once clean, what kind of protector would you put on it ?? … Can someone give me an idea …
Much more info required. Lightly sand or scrap depending on what, where.
Bit of rust on the surface or holes?
Bit of rust on the surface can be cured with sandpaper or wire brush then rust converter (to get what you’ve missed) then paint
Holes need cutting back to good metal then patches welding in then the above treatment
Use an angle grinder with paint stripper ‘disks’ like these.
Then treat with Bilt Hamber Hydrate 80 as a rust converter and primer. You can use this over good painted surface as well as bare metal.
You will need a chemical as well as mechanical process.
Then epoxy paint.
Cheers.
Dave
Ok…l will keep your information …thanks soo much…
Not sure what country you are in but check www.eastwood.com for every rust repair repair solution known to mankind.
Gerard
