[s-type] 05 S-Type
I am a female looking at a 2005 S-Type Jag,for as long as I can
remember was my dream car. This car has 39K on it with an automatic
transmission, should I be worried about transmission problems later
on down the road?–
ShayShay
Shay,
The S-types seem to have more problems with the transmission than other cars but the
2005 model should be better as it has a different gearbox than the earlier series of cars.
Are you getting the car from a dealer or used car place? If so pay the extra money to get
an extended warranty on the major components (engine, gearbox etc) as well as have
them do a service on the car and change the transmission fluids at that time.
Also this model car has problems with the window regulators (not a big deal) and
sometimes the coolent tank on the car cracks and leaks. Its a bit more expensive but not
that bad.
Have had my 2000 model for 4 years and love it, even with its warts!
on down the road?
ShayShay
In reply to a message from ShayShay sent Sat 24 Nov 2007:
Any issues with the occasionl gearbox failure can be avoided it
seems with a transmission flush around at the 60k ml mark.–
Dave (S type 2.7d Sport)
Personally I would not wait until 60k to do a fluid change. There are many documented
cases of transmissions failing at anywhere from 35 to 50k miles.
A fluid change is cheap insurance. Do it now and make sure the fluid is fresh. Then do it
every 30k miles. You can buy a lot of transmission fluid for the $2200 I just spent to have
my gearbox overhauled!
I had mine done at 30,000 when they added some snake oil to stop the
“eek” noise on kickdown, apparently it was discoloured and worth doing.
Kevin (05 2.7D SE)-----Original Message-----
From: owner-s-type@jag-lovers.org [mailto:owner-s-type@jag-lovers.org]
On Behalf Of joeaksa@attglobal.net
Sent: 24 November 2007 16:26
To: s-type@jag-lovers.org
Subject: Re: [s-type] 05 S-Type
many documented
fresh. Then do it
just spent to have
Joe
In reply to a message from Kevin Fox sent Sat 24 Nov 2007:
Kevin
Noting the age of your S-Type, was it a Jaguar dealler who
changed the fluid; mine in Peterborough stated they don’t
change the fluid, so thought I’d have to find an alternative
independent (near Cambridge/Peterborough, UK)?
Also what was the cost to do this?
(I have 37k miles on a 3.0SE 2003, but just want to plan on
this change perhaps next year around 46k miles)
Stuart–
‘‘eek’’ noise on kickdown, apparently it was discoloured and worth doing.
Kevin (05 2.7D SE)
S-Type 2003 3.0SE Stuart in GMC http://www.godmanchester.net
Godmanchester, United Kingdom
Yes it was a Jag dealer, they had to drain some off to add the magic eek silencing fluid so I asked them to swap the rest out if it was in any way discoloured, it was so they did. V expensive from what I remember for what it was (�67.29 for 3 litres of fluid and no labour). It changed smoother afterwards but that could have been the gearbox being reset.
From: owner-s-type@jag-lovers.org [mailto:owner-s-type@jag-lovers.org] On Behalf Of StuartGMC
Sent: 26 November 2007 20:55
Subject: RE: [s-type] 05 S-Type
Kevin
Stuart
Kevin (05 2.7D SE)
Mine had to have a new box at 13K due the ‘‘yelp’’ on kickdown. They
tried the additive serveral times and re-flashed the firmware on
the gearbox which just made it worse. New box is superb, no
problems at all, so far, fingers crossed.–
2005 S-Type 2.7D SE Auto
