i have 1999 jaguar s type 4.0 v8 it will not start I have no
spark the battry was flat so I’ve charged it, now it cranks,
I have fuel smell at the exhaust no fault codes showing on
the dash can you help me thank you–
wnderer
In reply to a message from wnderer sent Sun 5 Apr 2015:
First check the fuses and relays.
Under the bonnet:
fuse #5 is fuel injection #12 is coil on plugs #18 is powertrain control module
relays #3 and 14 are powertrain control modules
In the passenger compartment:
fuse #4 is powertrain control module fuel pump relay fuse
In the luggage compartment:
Relay #6 is fuel pump
Also look in the luggage compartment right rear corner for a
loose wire dangling down and touching the body. This is left
over from the transit relay which should have been removed
by the first dealer.–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
In reply to a message from Rob Reilly sent Tue 7 Apr 2015:
checked the fuse’s, relays & cranksensor today all are ok,
according to jtis I should have 10 volts at the coil pack’s
when the ign is turned to run, I’m not getting any voltage
at the coil pack continuity between the pcm & coil packs is ok–
1999 S Type 4L
In reply to a message from wnderer sent Sat 11 Apr 2015:
You’re sure about relay #14 in the front box? Actually
passing current between terminals 30 and 87, not just
clicking? You can pull this relay, put a jumper wire across
terminals 30 and 87 in the box and see if it starts.–
In reply to a message from Rob Reilly sent Sun 12 Apr 2015:
I put a jumper wire accross the 30 & 87 terminals still no
start I’ve been offered a PCM to try but not sure if it will
work with my key. does anyone know?–
1999 S Type 4L
Please note jaguar S-TYPE cranking just fine BUT won’t start after oil change if it is overfilled. You must suck motor oil back out using hand pump/ spray bottle with long thin straw.
