Hi Guys
Hope someone could help me…
my s-type 2002 2.5 v6 has a right tail light issue
the right signal is dimmed flashing with the reverse light on the right side also plate light is flashing and left-hand signal the reverse light on the right hand, when car reverse is not working when took the bulb of
the reverse out all flashing lights stopped but still no right signal
have checked the fuse changed the rear ECM got the same issue
on the rear light RHS the cluster connector I tested found that pins 1, 4 and 6 has volts of 11.30…
of the LHS I have checked found only 2 PINS 2, 6 on the connector has volts of 11.30 (All works fine)
Iḿ really confused the diagram of 2002.5 mentions that only 2 pins on each side should come from some relays …
Mag
