[s-type] sat nav
does anyone know what is the latest verion on cd for the uk is
i have the 1999 v was hoping to get a newer version.
richard–
ssrfr03
In reply to a message from ssrfr03 sent Sat 15 Oct 2005:
Same here I own a 1999 S Type and I would like to have an updated
version
Regards
Julian–
JFJ
In reply to a message from JFJ sent Tue 25 Oct 2005:
Your local main dealer should be able to tell you when the last
update was made for the 1999 model satnav. I have purchased a 2002
version which is an improvement on the 1999 version, but I do not
rate the satnav installation at all.
regards
Baz–
Doc S-Type
Nottingham, United Kingdom
should my sat nav go dim when I put mt sidelights on–
goldeen
derby, United Kingdom
My 2005 S-Type puts the SatNav into night mode whenever I turn on the
headlights - I would never drive on sidelights, which I belive are define as
parking lights. Night mode has a black background and is not easy to read at
night, but is impossible to read when lights are on due to poor visibilty
during the day.
If there is a fix for this I’d be pleased to know, bit I’m not holding my
breath.
Vernon
2005 2.7D SE
MK UK
Press menu on the console and then brightness/contrast once in that
screen you can turn off the automatic switching, as well as adjust the
brightness and contrast settings for each mode. There is a twilight
setting but on my 05 car it doesn’t seem to do a lot.
Kevin (05 2.7D SE)-----Original Message-----
From: owner-s-type@jag-lovers.org [mailto:owner-s-type@jag-lovers.org]
On Behalf Of Vernon Draper
Sent: 30 September 2010 11:23
To: s-type@jag-lovers.org
Subject: Re: [s-type] sat nav
define as
read at
visibilty
during the day.
my
breath.
Vernon
2005 2.7D SE
MK UK
In reply to a message from goldeen sent Wed 29 Sep 2010:
thanks kevin&vernon its reasuring to know this is normal .only had
car a month–
goldeen
Thanks Kevin. Today is a great day to test it, and I went to the settings
you described. But the only two options (apart from brightness/contrast) are
Auto and Default - pressing Auto didn’t turn it off. I’m probably missing
something blindingly obvious, but for now I’m still stuck with the black
screen when the headlights are on during the day.
Next option is to get out the handbook!
Vernon
2005 2.7D SE
MK UK----- Original Message -----
To: Vernon Draper ; s-type@jag-lovers.org
Sent: Wednesday, September 29, 2010 11:38 PM
Subject: RE: [s-type] sat nav
Kevin (05 2.7D SE)
define as
read at
visibilty
during the day.
my
breath.
Vernon
2005 2.7D SE
MK UK
