I need to fabricate the throttle link piece connecting the primary and secondary. Can someone measure and share the correct length below?
As an alternative, simply lock the secondaries open (STF). Helps with performance and you won’t need to fabricate the link.
Bad explanation Doug, it’s the main carb linkage, not the secondary sorry! I need this link, it’s the only connection from throttle linkage to carb linkage
Secondary linkage is removed, thanks to this group!
Sorry- I should have looked more closely at the image. I’ll try to get out to the car and get a measurement if someone else doesn’t beat me to it.
I measured 2 15/16" from center to center of the bent ends.
