I have a 1966 restoration underway; a new wiring harness, Coolcat fan and otter switch. The relay has positions of 85, 86, 87 and 30. The Coolcat fan has an orange wire and a B wire. The wiring harness for the fan has G and B wires. The wiring harness for the otter switch has BR and B wires.
I’m pretty sure I’d know how to wire this up without the relay, but with it I’m completely lost. Yes, this is the first time I’ve ever attempted to restore a car.
12 volt power goes to 30 with fuse protection for the fan a the source of the 12V
87 goes to the fan
12 volts goes to 86 (fused can use same 12 V as 30 above)
85 goes to the middle terminal of the otter switch
The outer male spade connector on the otter switch goes to ground
(The other connection on your fan goes to ground. Be sure you put the wire from 30 on the relay to the proper fan terminal or your fan will rotate backwards)
Hi Mike—the relay you sent me has 5 spades. my first you sent has 4. Is this a problem? I’m still in a fog on all the wires now going to and from the relay. Seems to me a power wire to the relay, a gnd and a power wire out of the relay. color or wires don’t seem to match either. any help appreciated
as it turns out, my CC relay wasn’t the problem (fan would not turn on). It was the new, aftermarket switch that was bad. I had a very old original otter that I checked using a heat gun-----worked perfectly. Removed the aftermarket one added the old–problem solved. Now I have a new CC relay that will probably sit unused for years:) Anyone need one?
