Well, as an update, I did finally take proper time to look at her…talk about procrastinating!
Once again, it is a US Series 3 motor. Per serial number, I can date it at 1984 I believe per what I’ve found here.
Therefore, 8:1 … fwiw.
While I wanted to do a cursory check to simply determine anything catastrophic, I ran a more proper compression check today.
Did it cold as I don’t want to run her anymore … been running around the neighborhood about 10mins. or so while keeping eye on any possible overheating with the infrared thermometer.
But as mentioned, coolant header tank was plugged at both exits with a u-hose, an a simple blanking cap that doesn’t seal perfectly allowing some coolant escape at pressure.
This was done before me and as received by SOB PO … due in part to rusted/leaking overflow tank as mentioned within other post.
Very short runs should be ok, short testings, but no more as I know it’s not good.
That said, while cold, all plugs removed, throttle open, each cylinder registers a solid 160PSI.
…while ole’ #5 registers 150…fogged it registered 155+
The wiring of the car while generally good elsewhere and original, all other items function excluding some lighting due to rather obvious issues…
However the ignition wiring is hard and wrapped with electrical tape, don’t like …so I cut that off today and exposed the original wires.
Although I simply replaced cap, rotor, plugs, plug wires … the wiring of the distributor is crap.
Never did check for arcing,etc.
So low and behold there is serious arcing of the points opened when ignition on.
Read a good comment, “90% of carburetor problems are ignition related…” or something to that effect.
I thought I tuned the hell out of them, but never could get it to idle well.
Strangely at higher revs ok…and revving generally …no backfires.
i noted it didn’t seem to have a strong spark so I bi-passed coil resistor to test, and noted wetness on the plugs which concerned me … unburnt fuel it seemed…
The spark always appeared weak…
Anyway, brought it in tonight and tomorrow will take it all apart and clean it up.
I have replacement points and LT lead on distributor housing as the fabric wound wire on it seemed older than me anyway.
In time I will eventually replace with an electronic E Type unit.
Hopefully this will resolve some issues.
As for mechanic’s stethoscope bit, don’t have yet. That will be final test, but I believe I have decided I am going to go with it all …stubborn and obsessed as I am. Top end not making any nosies at #5 … I opened oil filler and stuck ear in, all sounds normal up there.
Again, the hose to ear revealed sound from bottom end at pan area at #5.
So, if it is a main due to a spun bearing or something, I don’t want to score the crank worse than it may be.
Hopefully I dream to get away with being able to hand polish it and replace the bearings if in tolerances…
…however, I do get puffs of smoke out the exhaust under revs, so perhaps rings and/or valve guides, seals are necessary too?
Anyway, this car is a keeper. I will not make the same mistake I have made in past selling my classic for a “newer” model …only to regret it. Not this time, damnit!
Although values remain low when one DOES come across a Series 1 XJ6??..how rare are these cars?! Find one in decent ORIGINAL shape … I’ve had my eye out everywhere scanning for past couple years…I’ve come across maybe 2, within the US that is.
It blows me away they do not yet have the market of the E Type and Mk2…it is such an important and rare car.
As long as i focus and look past the paint, she is worth it…funny how paint can make such a difference.
So I will rebuild it, within reason. that is, whatever needs to be replaced, should be replaced, and is out of spec will be remedied…damnit!
I must be crazy!
kind regards
