Your problem description is a bit unclear, Dennis�
âŠbut the relay is a worthwhile starting point. A blue wire connects the light switch to relay #56; with the light switch âonâ - this powers either âhighâ beam (outer and inners), relay #56a blue/white, or âlowâ beams (outers only), relay #56b blue/red.
With light switch on; check for power on these wires/connections.
The relay has permanent power, brown wire to #81a - this provides switching power to the relay and âflashâ function; âhighâ beam power when the stalk switch is pulled at any time.
A ground wire, black, is connected to relay 31b - grounded by the stalk switch when pulled.
The relay has a latch function alternating between âhighâ and âlowâ beam by stalk switch action.
The wires from the relay goes to 4 fuses on the fuse box; âlowâ beam left outer + âlowâ beam right outer + âhighâ beam left, inner and outer, + âhighâ beam right, inner and outer.
Remember that âall 4 lights workingâ means that âhighâ beam is powered - brown to 56a (blue/white wires|will do that. Actually proving that there is nothing wrong with the lamps or fuses. âLowâ beam (white/red) only works the outer lamps - but both âhighâ and âlowâ beams is to be powered from the light switch blueâŠ
Checkpoint for power at fuses, verifying that power is delivered properly through the relayâŠ
Without a more complete list of the work done itâs uncertain what has gone wrong. It may just be the infamous âfiddle factorâ; while working in an area you have inadvertently touched tender points. Light switch connections springs to mind - but the first step is checking power at the relay for cluesâŠ
The key is wire colours and connection points - the brown wire is always powered, to be treated with care, it is unfusedâŠ
Frank
xj6 85 Sov Europe (UK/NZ)
