To Nick,
Your 2.4 probably has the twin Solex carbs. They could just be in bad shape (jets, etc.) and not able to adjust mixture etc. because of wear.
Per other lister, go right to back to square one with plugs, distrib., fuel filter? then adjusting idle and mixture.
The only thing I have found over the years is that when it is right, it will stay that way almost indefinitely.
Terry Watkinson
Mk II 2.4 1961.
[Commercial use of subscribers e-mail addresses prohibited.]==============================
hi all
i would check the compression.The rough idle could be the sign of a bad
valve
hugh 58 3.4 85 xj6----- Original Message -----
To: saloons@jag-lovers.org
Sent: Thursday, June 19, 2003 10:16 AM
Subject: [Saloon-lovers] 2.4 idle
To Nick,
Terry Watkinson
Mk II 2.4 1961.
